Cessna R172K Hawk XP II Brake Upgrade
I am looking to put some new shoes on my Hawk XP II and I am having trouble getting a definitive answer from multiple shops! I understand that if I go with >26" ABW on the mains, I may need (paperwork says I DO need) a heavy duty brake upgrade. So, do I need that or dont I? If yes, WHO makes it? I cant seem to find the R172K listed on their double piston systems. I am sure someone here has done this before!
Thanks
Ned
SuperFly offline
2
- Aircraft: Cessna R172K
I would give Alaska Airframes a call. I am sure they will have an answer for you.
1269
I havent read the STC instructions but...
If the STC says you need certain brakes then you do.
Unless you get the feds to sign off a field approval on a deviation.
TangoFox offline
621
Keep the Greasy side down!
