Backcountry Pilot • Checking Fuel on High-Wing
32 postsPage 2 of 21, 2
Re: Checking Fuel on High-Wing
wait another week. As the heineken err corona virus keeps the markets down the price might be about right.
soaringhiggy offline
48 Stinson 108-3
I inherited a little harbor freight folding stepstool when I bought my bird.
It's tall enough for me to reach the top of the wing on my Tripacer. I can use it to dip the tanks, check caps, and pour gas cans in the tanks. it folds down to about 12 x 20 x 8 inches and fits great in the baggage compartment without taking up too much space. Cost about $30 and you can get it for less with a 20% off coupon that Harbor freight send in the mail every month.
Huskytracks offline
Aircraft: PA-22
Anyone remember the "Step 'N Chek?" I have one that I take along when I'm not topping off and know I'll need dip the tanks. It can be a tricky little devil. Recommended by spouses of orthopedic surgeons everywhere.
CAVU offline
found one on ebay. How tall is it?
frstnflt offline
Aircraft: Cessna 185
The originals were just tripods. I think they might have been as much as 20-24" tall when extended. I have one with extendable legs that goes maybe 10 inches higher. It's ok for dipping the tanks. I would not want to balance on it while pouring fuel out of a container. It would be marginal holding a fuel hose.
I'll post a pic when I get down to the hangar.
CAVU
CAVU offline
Here are the pics of the "Step N Chek." It's the deluxe version with extendable legs.
I've used it at minimum height to dip the tanks. I'm 6'3", so it's enough. I'm also 220 lbs., and not inclined to trust those little buttons to hold my weight 26 inches off the ground.
YMMV
CAVU
CAVU offline
Just scored a Fall N Break on Ebay! Probably a great reason they stopped making them.
frstnflt offline
Step N Check came!
Very lightweight and compact. Will hardly notice it in the baggage compartment. My favorite part about it is the Ahhhhh............
frstnflt offline
https://amzn.to/30ibULC
This thing has been pretty solid and is small enough that I haven't had an issue stowing it yet. 6.3lbs.
Reason: Added associates link
TheWireman offline
Aircraft: Stinson 108-1
frstnflt wrote:Step N Check came!
Looks kinda 'iffy' if used on a grass strip. Or sloping ground. Say, is that cement hangar floor got a little slope to it?
PapernScissors offline
Aircraft: Cessna 172
I was searching for a compact lightweight step as well and found a used step n check. It’s very handy. I guess I have the deluxe version that extends as well.
Barrakudaman offline
Aircraft: 1960 Cessna 182
Nope on the slope. 3 feet is better if surface uneven and I would feel better about falling on grass. I've been using before almost every flight to confirm it was filled or dip the tanks unless there was a step ladder close. It would be challenging to fill the tanks with it with pump or cans but possible. Highly recommend.
frstnflt offline
