The ranch immediately below and along side the Mount Borah (highest Peak in Idaho) access road used to have a strip right by the farm buildings, they had a Super Cub. It was hard to distinguish from the pasture and the feed lots, but it was there if you knew what to look for.12 years ago I landed on the dirt road as close to the trailhead as I could get, tied the plane down and left my stereo on (with a 10 watt PV panel on the skylight to keep the battery up) to keep the cattle away and started hiking. 8 hours later upon arrival back at the tie down spot, I had a ring of curious cattle all around the plane, but none closer then 50 feet. Right about then a ranch hand drove up to check the head gate on their irrigation system, and we had a good laugh at the curious cattle...as scarey as the hike up Borah was I was more worried about the cattle. The old boy who ran the operation was named Wiley, and just a real great guy, a real Idaho cowboy/rancher and friendly as hell.
I rig a cable choker to my mid size Kubota, and easily pull the biggest sage brush, it helps if you have someone to rig and you stay on the tractor. If you are on a budget/have no money (like me) you're 8N will do the job (I used to have one before the Kubota), clear the brush first, you may get lucky like me and find it's good enough, and naturally drained, as is. Pushing a lot of dirt around first can screw up what is already working fine...if you have a few swales, so what, if you can handle it, point is it doesn't have to turn into a major engineering project to be usefull, and if it's a little funky it'll keep the riff raff out! This all depends on your aircraft type of course.
MGUS wrote:I'm facing a bit of the same problem. I have 40 acres about 13 miles southeast of the Wine Cup Ranch between Jackpot and Wells. I have about probably 2000 feet to put in an airstrip, and not with the winds working in my favor. I want to put one in pretty bad, because, what I do, I really like getting away from people and the world. (no offense) It is one of the most remote places in the U.S. You can see about 100 miles in just about any direction, hence the fact it is hard to get to. However, when it does rain, you can pretty much kiss any contact with that area goodbye for awhile. I drove there last fall. (I'm always on the road otherwise) It was a real pain to get to. Probably the least available country in the U.S. I have pictures but I will have to figure out how to post them... not so savvy with the ol computer.....
My brother has the adjacent 40 acres and we are talking about trying to get something erected there, whether it be a yurt, or a small cabin. Yurts are easier....by far. My friends just put one up for 10K on their land at the base of Mt. Borah in the Lost River Valley of Idaho. Right by Chilly.... (north of Mackay) Took a nice flight over that area this fall in a friends 210 and got a great view coming down Trail Creek on the way into Sun Valley. (aka the worst place to fly into if you aren't loaded with money or know someone who does) Either way, let me know what you can figure out as far as work goes. I am up against the same odds. I can probably get a lot of farm equipment from Twin Falls for a discounted price, (Jerome actually) I just need the time to do it-which doesn't come easy. (loaders, tractors, you name it, my brother is a Dairy farmer there) The area that you showed pretty much is the same as where I have land. That being said, it will probably be years from now.....work comes first, have to make the money. Have to have the money..... I at least have the land for now.....
