mtv wrote:Zane,
The notion of on a moment's notice hauling someone for hire isn't going to happen, at least not legally. To do so, you'd have to apply for and acquire an FAR 135 operating certificate. That's a lot of work, money and time. ...............................
I realized that this isn't exactly true. There's a loophole in the regs, which may be in the process of being plugged, that allows for scenic flights for hire. There is a limitation of (I believe) 25 nm and also no landing other than where you took off-- anything more and you need a part 135 operation (aircraft AND pilot). You need a commercial ticket of course.
Not sure if this is allowed in an experimental. I would think no, except for the fact that a lot of warbirds seem to hop rides and I'm not sure that P-51's for example carry a standard airworthiness certificate,I'd think it'd be an experimental-exhibition.
Eric
