Fri Jan 12, 2007 12:36 am
AV gas has a very high octane rating it is also a very slow burning fuel, it is designed to run in low compression engines at a constant rpm, the reason for the higher octane is the altitude. Running AV gas in a car engine will result in a very slow burn or flame front, power will be low, and overheating will often result from the delayed ignition.
To obtain the maximum energy from the gasoline, the compressed fuel-air mixture inside the combustion chamber needs to burn evenly, propagating out from the spark plug until all the fuel is consumed. This would deliver an optimum power stroke. In real life, a series of pre-flame reactions will occur in the unburnt "end gases" in the combustion chamber before the flame front arrives. If these reactions form molecules or species that can autoignite before the flame front arrives, knock will occur.
Simply put, the octane rating of the fuel reflects the ability of the unburnt end gases to resist spontaneous autoignition under the engine test conditions used. If autoignition occurs, it results in an extremely rapid pressure rise, as both the desired spark-initiated flame front, and the undesired autoignited end gas flames are expanding. The combined pressure peak arrives slightly ahead of the normal operating pressure peak, leading to a loss of power and eventual overheating. The end gas pressure waves are superimposed on the main pressure wave, leading to a sawtooth pattern of pressure oscillations that create the "knocking" sound.
The combination of intense pressure waves and overheating can induce piston failure in a few minutes. Knock and preignition are both favoured by high temperatures, so one may lead to the other. Under high-speed conditions knock can lead to preignition, which then accelerates engine destruction...
Aviation gasolines were all highly leaded and graded using two numbers, with common grades being 80/87, 100/130, and 115/145 [109,110]. The first number is the Aviation rating ( aka Lean Mixture rating ), and the second number is the Supercharge rating ( aka Rich Mixture rating ). In the 1970s a new grade, 100LL ( low lead = 0.53mlTEL/L instead of 1.06mlTEL/L) was introduced to replace the 80/87 and 100/130. Soon after the introduction, there was a spate of plug fouling, and high cylinder head temperatures resulting in cracked cylinder heads [110]. The old 80/87 grade was reintroduced on a limited scale. The Aviation Rating is determined using the automotive Motor Octane test procedure, and then converted to an Aviation Number using a table in the method. Aviation Numbers below 100 are Octane numbers, while numbers above 100 are Performance numbers. There is usually only 1 - 2 Octane units different to the Motor value up to 100, but Performance numbers varies significantly above that eg 110 MON = 128 Performance number.
The second Avgas number is the Rich Mixture method Performance Number ( PN - they are not commonly called octane numbers when they are above 100 ), and is determined on a supercharged version of the CFR engine which has a fixed compression ratio. The method determines the dependence of the highest permissible power ( in terms of indicated mean effective pressure ) on mixture strength and boost for a specific light knocking setting. The Performance Number indicates the maximum knock-free power obtainable from a fuel compared to iso-octane = 100. Thus, a PN = 150 indicates that an engine designed to utilise the fuel can obtain 150% of the knock-limited power of iso-octane at the same mixture ratio. This is an arbitrary scale based on iso-octane + varying amounts of TEL, derived from a survey of engines performed decades ago. Aviation gasoline PNs are rated using variations of mixture strength to obtain the maximum knock-limited power in a supercharged engine. This can be extended to provide mixture response curves which define the maximum boost ( rich - about 11:1 stoichiometry ) and minimum boost ( weak about 16:1 stoichiometry ) before knock.
sector15 on Fri Jan 12, 2007 8:20 am, edited 1 time in total.
