Confusing firewall find
Fri Jul 03, 2020 11:55 am
Kickrjason offline
21
- Aircraft: 1958 Cessna 182A Skylane
Fri Jul 03, 2020 12:47 pm
Some of the old stuff can be confusing. There where two solutions back in the day for making differing voltages or things like AC. There was a collective term of Dynamotor for them. They used a small motor to turn an equally small generator or alternator to make whatever voltage you wanted or flavor of electricity needed. So if you disconnect it and nothing changes, it is simply a relic of electronics/electrics past. You would need to do a 337 to remove it, or, if there was a 337 removing the old AC beacon, then just simply remove it.
Old military aircraft where full of these things, whining and failing right and left. Personally I think them to be hazardous, since they had a tendency to smoke check when they ended their lives.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
It's a noise filter for your radio, or for a previous radio that has been removed. It keeps generator whine out of the radio. you can buy one on E-bay right now for $65.00 plus shipping.
Dale Moul offline
523
Dale
Gravity Strikes Again.
