continental service bulletin
Anyone know where I can find a copy of Continental service bulletin m80-18 about placement of the engine breather on io360's online
Thanks
akm4 offline
5
I don't, but am interested. I just moved the oil/air separator on mine. Is this a new service bulletin?
skymaule offline
203
Came out in 1980. I have what seems like to much oil out the breather and thought it couldn't hurt to see if the position was correct.
akm4 offline
5
Sat Dec 27, 2008 10:08 pm
akm4 wrote:Anyone know where I can find a copy of Continental service bulletin m80-18 about placement of the engine breather on io360's online
Thanks
Go to Continental web site and register
http://www.tcmlink.com and you can get all the SB/ A.D.'s etc.
182 STOL driver offline
1529
Sun Dec 28, 2008 12:20 am
The hot tip for the breather on the smaller Continentals (up to O-300) is to turn the breather elbow coming out of the crancase up above horizontal a bit, then straighten the breather line back out with the hose. Oil mist collects there & drains back into the engine. They also make a elbow with a straight extension on the end that screws into the engine, helps to prevent that oil mist from blowing into the breather to begin with.
Eric
10534
hotrod150 wrote:They also make a elbow with a straight extension on the end that screws into the engine, helps to prevent that oil mist from blowing into the breather to begin with.
Eric
Almost certain that this was used on the 150 aerobat. Not a cheap piece either, but many have been made by silver soldering an extension on to a common elbow.
a64pilot offline
1398
