I know others have found other, cheaper alternatives, but Mike's stuff is for sure the bomb...
http://mountainwaveaviation.com/
This is the net Mike made for my Wagon. Hangs on the rear carry thru...
robw56 wrote:Here's what I did for my 170. It's a 23.5"x23.5" net from http://www.safarinets.com they specialize in nets for jeeps and other off road vehicles. Not bad for $55.
How are you attaching the upper end behind the front seats? Sharing the seat belt points?
My load cells might only do 5kN I think, but we could rig up a pulley or use a couple of them to do the job. Otherwise I think I have a friend with a few that might be over 10kN. Get a hold of me and we can measure for your nets too.cubscout wrote:I need to talk to you about nets for Supercubs, ~23"x23". Also have an idea for a tiedowns from webbing, with grommets, using bridgespikes. Should be light and inexpensive. Know where we can borrow a straingauge in the ~750-1000 kg range to pull-test?
