EZFlap wrote:I'm definitely not a high time Cub driver (a hundred or two hours in a J-3), but I believe that the reason for the religious loyalty that so many people have for that wing is that it is not only predictable at all times... but it is trusted to be very gentle when pushed to its limits. It's definitely not the most efficient or highest lift, but I believe that when put into the really harsh environment (aerodynamic) that some bush aircraft fly in, it allows the airplane to be flown right at its limits without any surprises.
The "real" bush guys here can correct me, but I remember hearing a story that a large government agency switched from the Super Cub to the Christen (Aviat) Husky because it was "better" in some way. But after a while they had people getting hurt because the Husky could not hang in there safely at the lowest speeds and tightest turns. And the Husky wing was VERY similar to the Cub, both flat bottom bigh lift wings. So apparently they went back to the Cubs. I'm sure s omeone here knows the details of that story.
Another important thing is that all the graphs and wind tunnel tests and NACA aerodynamic data and all the theory in the Abbott & Costello book do not factor in the real-world conditions of dirt, leading edge lumps and bugs,pinked edge tape, duct tape, mud splatter etc. that wind up on these wings. I suspect that this is one of the big things where Cub wing owners know that their wing is not sensitive or greatly affected by all this mud and moose poop. It is completely possible (likely actually) that you can hve a "book" airfoil that is twice as "good", twice the L/D, twice the lift, etc. and if you built identical Cubs with each of these wings the old crappy USA-35 would fly better and do more in real-world operations. There's a guy named Bill Montagne who found that out the hard way.
Here we go again with the old "I've never flown one, but I heard a story....." BS, pure and simple. You heard wrong.
The Husky wing is pretty close to the Cub wing, both in airfoil and planform. That airplane has no ugly stall characteristics that I've ever been able to discern....and that's based on over 3500 hours of working the airplanes, not "I heard....".
The problem the Border Patrol had was the flight profile they were flying with the airplane, not the airplane.
Forward CG? Not the ones I've flown, and I've flown them in most of the worst case configurations (amphib floats and retractable wheel skis). Yes, they tend to be somewhat heavy forward, particularly if the 80 inch Hartzell propeller and harmonic damper are installed (it wasn't on the BP airplanes). But, I've flown several hundred hours in Huskys with that setup as well, and it is easy to remain well within the CG envelope.
A couple of agencies have now switched back to Top Cubs, for several reasons. Not the least of which is that Aviat has not always treated their customers well. And, there's always that old "you can't beat a Cub" legend.....true or not.
Both are good airplanes, and flown well, they'll do a great job for you. But, dangerous stall characteristics? Nope. And, I've stalled them both many, many times, and poked them in all sorts of ways to see just how ugly they can get. Neither has any really ugly corners.
One is better in circling flight, down low? Again, horse pucky. How many Super Cub pilots have screwed their airplanes into the ground in the infamous "moose stall"? ANY airplane can react badly in that environment. I don't circle stuff close to the ground any more. I knew too many pilots who were killed circling animals close to the ground. Several of those were in Super Cubs, one in a Husky, one in a Taylorcraft, and one in a Cessna 185. One or two of those had witnesses on the ground.
I firmly believe that these are all cases of the pilot allowing airspeed to decay a bit (remember that stall speed increases as bank angle increases) in the turning, maybe kicks just a bit of rudder in to move the "target" out from under a wing tip, and gets just unlucky enough to encounter his/her own wake vortex in just precisely the wrong angle and place to trip the wing. And, do that at low level, and you're very likely to meet your maker. I know one gentleman, a superb pilot, who did just this and survived. His airplane (a Super Cub) rolled over the top and spun, but as it entered the spin, it struck a canyon wall inverted, and slid down the canyon wall. Both occupants were severely injured, but lived. The pilot, a very experienced Cub driver, is convinced that what caused the departure from controlled flight was a wake vortex encounter of his own wake.
Note that this is an entirely different scenario than the Border Patrol accidents, where the airplanes did not spin, they went straight in, nose down.
FWIW. Don't circle stuff on the ground at low level....there are much better ways to look at stuff on the ground. And, don't spread BS rumors.
