GroundLooper wrote:Bear_Builder wrote:The problems I'm seeing is where manufacturers and owners are trying to use Light sport planes as utility planes. That's why I think the LSP weight limit should be LOWER not higher.
But isn't there already a definition for that "Ultralight"?
Craig.
Actually No. This is the side of LSP that most pilots done think about. Part 103 does
NOT address 2 seat ultralights, and neither did any other FAR. The FAA was issuing waivers to allow 2 seat "ultralights" for instructional use only ( I use quotes because an ultralight is defined as having only 1 seat). The problem was that most of the 2 seaters were being used for recreation and taking a spouse, kid or buddy for a ride. This put them outside any existing rules or definitions. One article I read in Custom Planes listed exactly what a 2 seat heavy ultralight pilot could be fined for if not giving instruction. It totaled 7 violations with a typical fine of $1000 each.
And since there were no standards for training, there were increasing numbers of accidents and problems. I know one local airport here that had numorous close calls because the ultralight pilots there (all flying 2 seaters and taking passengers) weren't following pattern rules. For the most part, they didn't even know there were pattern rules! The FAA seems not to care if an ultralight pilot kills him or her self, but once they started taking passengers things changed. So what the Light sport rule did was 1. Offer a leagal way to fly a 2 seat 'ultralight' for recreation. 2. ensure there was minimum training required for taking passengers. 3. set standards for construction and maintenance of 2 seat ultralights.
Oh yeah, and 4. Let aging pilots with expired medicals continue to fly something other than a 254lb single seat lawnchair.
Phil
