stewartb wrote:It seems to me that the total performance of any airplane diminishes in thin air. Improving thrust makes some sense. Increasing HP, or at least increasing HP alone, may not be the best way to achieve it. Prop improvements and wing improvements need to be considered. At face value I'd think a CS prop would do more for improving performance than adding HP behind a fixed pitch can. It's interesting to think about, though.
Polishing ports smoothes out casting irregularities and allows improved air flow. Flow matching should be done to balance all the cylinder's potential as well. If improving air flow potential inside the engine is to work that engine must have induction and exhaust flow potential to spare. Otherwise cylinder flow improvements can't be realized. I recently replaced an almost brand new Cub muffler with a Hot Rod muffler. From the benefits I saw after the change it's apparent that my stock muffler was holding my 160hp 0-320 back. I know lots of guys using the identical muffler on 180hp Cubs. Some with tuned cylinders and higher compression pistons. They'd have been better off accommodating increased flow than just spending the money on cylinder mods for cylinder mods' sake. The point is that there's more to total engine performance than cylinders.
Agreed. I had already done the easier performance gains. My O 360 is rated 180 hp at 2700 rpm. That is without a set of mufflers that happen to best fit within a particular cowling designed or to make cabin heat with restrictive baffling. It is 180 hp without additional muffler restrictions. Got restrictive exhaust? Subtract more hp yet.
I had sent money to a company called Aircraft Exhaust Inc. out of St. Paul Minn. They did work similar to Power Flow in Florida, providing low restriction exhaust for aircraft, only this company had half the price because they specialized in experimental aircraft. They got my down payment and went belly up. After licking my wounds on that I found Vetterman Exhaust, nearly in my back yard at Hot Springs, SD. He has become the standard in performance exhaust systems for Van's Aircraft and his systems are sold through Aircraft Spruce. Once he knew I had a two into one exhaust system on each side he had me look inside the mufflers. I saw an inverted cone baffle inside, which he said is one of the more restrictive designs and was made primarily to hold back exhaust for the purpose of heating the muff for cabin heat. Moving from that design to his cross flow exhaust he guaranteed a minimum of 15 hp advantage on my 180 hp over the present exhaust. That doesn't mean I would get 15 over the 180, that means I would get back the 15 that it was shorted by the present system, and possibly 20 hp. So I really never actually had 180 hp with this system in the first place. Vetterman built me a cross over system for my Tundra after I sent the measurements to the firewall from rear exhaust port of a O 360 and the distance down to the cowling ramp point of exit. The cross over system pipes exhaust from cylinder no.1 to the other side of the engine and joins with cylinder 2 in a common pipe and then 3 and 4 are piped together in a second one, so two separate pipes exhaust. The one I got uses no mufflers. I wanted to try that first before deciding to add mufflers. What I found is that the outlets were too close to the cabin floor and loud and I had to use a turn down on each to quiet them. Not bad then and the Bose headsets finished it off.
The heat muffs are mounted on each pipe where there is sufficient straight tubing soon after the joining Y, where the two pipes come together. He said cabin heat would not suffer with the long pipes of the big Tundra cowling and I would not need to add studs to the pipes, so I got by cheap. Turned out the measurements were nearly the same as he had designed previously for the Glass Star. 800 bucks and shipping and I had it in a week.
It was after I made the changes to my exhaust system and added the constant speed MT prop that I went back to the hp well. I will eventually have a mountain performer. The whole story takes a book.
