I'll bet that they mined the FAA registry and are focusing on the 180/185 market. I got one of those as well.
hotrod180 wrote:I see that Desser's flyer mentions GarAero adapters & Clevelands as wheel options, but very pointedly does NOT mention the ABW 10" wheels.
Anyone have any idea of the price & availability of the Cleveland 40-101, 40-223, and 40-129 wheels they list?
gbflyer wrote:Use the 10X6.5 cub wheel from ABW?
gbflyer wrote:Ahh yes. That's a problem.
mghallen wrote:Ah yes but the 10" Clevlands give you a huge advantage over other wheels, the larger brake rotor and increased braking power.
bigrenna wrote:mghallen wrote:Ah yes but the 10" Clevlands give you a huge advantage over other wheels, the larger brake rotor and increased braking power.
z
I think the weak link in the 31's is that they are stiff. These new tires are reported to have a much flexier sidewall AND a more durable wear surface, which is why they are going to be a much better option than the ABW.s RE: the brakes, not sure what you are referring to. Both the Gar Aero and the 10x10 ABW use the same disc.
At the show, Grove spoke of being on the cusp of making wheels for the 31's. These may have larger diameter discs, but that's out of my wheelhouse. All I can say is that I am running 29 ABWs and double pucks on my 1800 lb Wagon. When I land in the grass/gravel, I can already lock em up tight, so Im not sure what a larger disc would net me. (that said, I very rarely fly at or even near gross, so perhaps there may be a benefit...)
bigrenna wrote:FWIW... I was just about to buy a set at OSH but was swayed not to. The down low from Desser (at OSH) is that they are just about to announce a true 29" Bushwheel. Tire is already made and just working it out with the feds. The tire will have the same compound as the 31s on the ride surface, but a much more flexible compound on the sidewalls. Tires will have the same AML as ABWs. Tubless, 6" wheel, super tough long lasting on pavement, and very flexible for off airport. In the words of the rep, this is going to be a "bushwheel killer."
Tom wrote:Finally! Bushwheel needs some competition to bring the prices down
