I need a Tech Counselor near Boise. Hopefully with a set of scales or access to some.
Thanks
EB
qmdv wrote:That is a post that needs more info. We know you are looking for a plane so what are you looking at.
kevbert wrote:You don't need a certified scale for what you're asking for. Just have the owner get three bathroom scales and put one under each wheel. If you want to calculate the balance, you'll also need to know the distances of the wheels from the datum point.
It's supposed to weigh 450lbs. I doubt it. Hopefully it hasn't gotten to 625 or something.kevbert wrote:a+b+c![]()
That plane should be light enough to use bathroom scales.
If deriving the balance from the weight, you have to make sure all the scales are at the same height, i.e., that the plane is level.
Emory Bored wrote:I need a Tech Counselor near Boise. Hopefully with a set of scales or access to some.
Thanks
EB
It's in Boise STOL driver. 0 TTAF 0 Time SFNEW. It doesn't need an annual, it needs an evaluation. I'll call the factory tomorrow. It's 20 miles or so from the airplane. Thanks for the offer.182 STOL driver wrote:Emory Bored wrote:I need a Tech Counselor near Boise. Hopefully with a set of scales or access to some.
Thanks
EB
Is airplane in Sparks ? I may be going to Washington --have scales and W&B computer program . I do W&B ,Prop balance , Prebuys , Maintenance,rigging , Airworthiness etc. See my web site http: edmaircraft.com
Have tools can travel
Kool! Makes sense.kevbert wrote:a+b+c![]()
edit: since you just want the empty weight (accurate to within a couple of lbs.) you can just weigh each wheel separately with one scale. When only one wheel is up on the scale, you're tipping some of the weight onto the other wheels, so put a 2x4 or something under the other wheels to make it more accurate.
I just wrote a monster reply to this but sent it off to cyberhell by accident. Yes, I understand where you are going with all that. Here is how Jabiru did the CH-701 cooling.EZFlap wrote:That's bloody adorable... good for you! A little mini L-3 Grasshopper
Please understand that the Jabiru cooling problems may be solve-able with a little cleverness and some cowling work. I am by no means a Jab expert but I have several decent ideas on cooling systems. PM me if you get the airplane and want to chat about this. <snip> I'll be happy to offer some ideas and work with you on it when you get the airplane if it is of any value.
Who is that guy? He's the dude that wrote up the full on test program for his install but I can't find it. Do you remember the thread I'm talking about?Av8r3400 wrote:The cowling on that plane looks almost exactly like the cowling on a friends Avid mk IV with a Jabaru. I'd bet it is based from the same cowling. The only difference is he does not have the big chin scoop. He has a NACA duct going to an oil cooler in the chin position.
(He has no cooling issues.)
Updraft cooling is a viable option for this applicaion... A big plus is it will help defrost the windscreen... A big negative is if you get an oil leak the windscreen will turn into a big pair of foogles...
Ben.
