Super-Maule wrote:Hello z3skybolt,
I have a M-4 Maule with a 210 HP IO-360. At a gross weight 2300 pounds, I can get a 1000 FPM climb at VX 70 MPH. With just me an half tanks I can
maintain a 2000 FPM climb at VX. A VY climb of 90 mph will give me at least a 800 FPM climb at most weights and DA(s), and thats at 2500 RPM at 25' MP too. Normally at cruise I operate at 23 squared (RPM & MP) that equates to 10 gph. I fly
a lot of differnt airplanes and consider the 210 hp Maule to be a real performer ie: thrust to weight. You must have a tired engine, or the trim-ball is in the ash-tray?
James
Thanks Jim,
Indeed you must have a Super Maule. I had a 260 HP Skybolt that weighed 1,200 lbs. It would not match your climb rate except during the first three or four thousand feet, nor would my 180HP Pitts S1 which weighed 760 lbs empty. Sure off the ground the Pitts and Skybolt would do around 2,500 fpm but above 7 or 8 thousand they would settle down to about 1,200 fpm at 120 mph.
I played with my Maule today. Light and 82 degrees temp. airport altitude of 485 msl. Climbed at 70 mph, as you indicated, until 800 ft. agl at over 1,000 fpm. But one cannot maintain such an low speed in my airplane for very long...it will stop climbing. Cruise climb at 105 mph and it settled back to around 500 fpm. above 4000 ft. The engine has strong compression. The airframe seems a bit out of rig however as the ball always wants to stay slightly out to the right until in cruise...then it settles into the middle. If I use enough right rudder trim or a heavy foot to keep the ball centered during climb then it takes a bit of left aileron to keep it level. Maybe that is part of my performance problem. Always been that way since I bought it ...nine years and 700 hours ago. I too fly and have flown dozens of different light airplanes....still think my Maule is not up to par in climb.
Just flew it 13 hours from Blanding Utah to Phoenix to Washington, Mo. Cruised as high as 11,500 ft. Took a long time to get there....but it made it. Averaged 10.5 gph at full throttle(about 20 inches) 2450 rpm. and 1320 egt. 66 gallons of gas. Me at 180 lbs, the wife at 110 lbs and enough camping gear to gross it out. Air temps from 80 degrees at PHX to a low of 29 degrees en route over New Mexico.
Has nothing to do with climb performance....but landed at Taylor, AZ.... near gross, density altitude of 8,900 ft. ...winds 210 degrees at 28 gusting to 40. right down the runway. Flew it on with power and 80 mph indicated. Smooth as silk touch down(actually just flew it on with a ground speed of about 45 mph). Take off from there in the same conditions at gross weight with a 400 fpm rate of climb.
Landed at Alexander, New Mexico.....winds nearly the same, slight cross wind very gusty. Lousy landing, headed for the toolies for a moment. Took a bunch of hard left brake to straighten it out. Could hardly taxi....90 degrees to the 30 mph winds. Take off there the climb was 500 fpm at gross wt. and 74 degrees temp. Lots of gust on take off. Stayed in ground effect until the stall light stopped flickering.
Liberal, KS. Winds 140 at 25 gusting to 35. Landed on runway 17 with the 30 degree crosswind. Spent the night as we had waited out terrible weather in Arizona for 3 hours.
Got home on Friday to an easy 20 kt. wind with a 30 degree crosswind. 8 hours of planned flight turned into 10 as we did a bunch of deviating around and under weather from that nasty cold front that blew through AZ, UT and NM Thursday.
By the way...when I got home I found that the tail wheel was no longer steering....just castering. Looks like a rebuild of the Scott tailwheel. Might have accounted for the wild gyrations after touch down at Alexander, NM. The Maule is a fantastic airplane. My wife is one brave lady with too much confidence in her husband.
Thanks to all for your thoughts. I am going to look into the rigging.
Bob
