Thu May 08, 2014 12:42 pm
If you got the hinges off the doors, you're doing better than many of us who have broken or stripped the screws holding the hinge onto the doorpost. When you reinstall the hinges, consider getting good quality, hardened Torx head screws or small hex bolts instead of the AN screws. Some of the AN screws are softer and lower strength, and can more easily be stripped out by the screwdriver tip. Using hardened screws means that the hardened screwdriver or Torx tips will not goober out the head as quickly , leaving you with a poor man's "anti-theft" fastener.
On my project, I fully intend to run a tap through the nut plates inside the doorpost, thus eliminating the oval "self-lock" part of the system. I'll lubricate it well with moly grease, and then safety wire or lockwasher the screws or bolts in place. This may or may not be acceptable under an overly draconian interpretation of Part 23 or Part 43, but I believe the ease of maintenance is well worth it, and it does not harm the structural integrity of the airplane. It essentially substitutes one Part 23 / Part 43 approved safetying method for another.
In your procedure for removing the old rusted pins, you can wiggle the hinge to determine which side of the hinge that the pin has seized. That way, you can put the correct half of the hinge into the vise, so you are not hammering on the wrong part.
+1 on the mixture of acetone and ATF fluid. There had been some published test that showed this mixture was superior to commercial oils.
Also, use several warm/cool cycles with a hair dryer or heat gun to expand and contract the hinge lugs. As they expand and contract, use an engraving pen to vibrate the hell out of it all, which will allow the ATF mixture to creep in. If you have room to do this, you can also spray some kind of aerosol propellant on the pin to cool/shrink it, while the hinge lugs are heated and expanded.
