This is a cautionary tale to owners that when the transducer ground wire loosens and falls out of these setscrew connectors, you may see your oil pressure swinging pretty erratically. Other wires and instrumentation would be equally susceptible. If you don't have the miniature metric allen wrench in your tool bag, you might want to add it. You might also want to check the tightness of those little setscrews the next time the cowl is off.
