My mechanic looked at the Atlee box and asked where I wanted it. This was on a 175. I agree that you have some latitude on where it’s installed with that STC.
mtv wrote:......... On my 52 I just replaced the stock battery in the stock box with an Odyssey, shimmed with foam. Simple and mechanics had no heartburn. ....
\hotrod180 wrote:mtv wrote:......... On my 52 I just replaced the stock battery in the stock box with an Odyssey, shimmed with foam. Simple and mechanics had no heartburn. ....
This was my plan installing an Odyssey on my old C150/150TD.
But my IA didn't like the foam, as he felt it could produce toxic smoke / fumes if it got hot or caught fire during a battery "event".
This was with the battery box mounted inside the airplane, aft of the baggage compartment.
I ended up fabricating a hat-section-shaped spacer out of aluminum which mounted to the box with two screws,
to take the place of the foam "shim".
