Earthx mounting box, thermal protection model required?
Mon Dec 07, 2020 12:15 pm
I’m looking at replacing an Odyssey battery with an EarthX, and have a question about the boxes.
I understand the Earthx won’t fit into my Odyssey box. So the choices on Earthx’s website are stock ($59), and thermal protection ($115). Both look as though we can use the same holes in the firewall.
How hot does it get on the firewall of a 180? The EarthX temperature limit is 140F. I looked up the Odyssey, and it’s limit is 113F.
Intuitively; since the limit is lower on the Odyssey, I’ve never seen a thermally protected Odyssey box, and mine has been there on the firewall for about 8 years the thermal protection is not necessary.
Does anyone have any advice on this, or the EarthX in general?
Thanks
aqua offline
237
aqua wrote:I’m looking at replacing an Odyssey battery with an EarthX, and have a question about the boxes.
Thanks
What are you going to use for a basis for approval? My understanding is that these batteries are not recommended for mounting in the cabin of a plane unless they're vented....not sure what that implies, but.....I'm sticking with my Odyssey till there's a lot more operational history on the Earth X batteries. They do sound good, but.....
10514
MTV, We'll have to get a field approval.
And the operational history knowledge bank is growing. I'll report back if we follow through with it, this spring at annual time.
aqua offline
237
Tue Dec 08, 2020 10:17 am
mtv wrote: ...My understanding is that these batteries are not recommended for mounting in the cabin of a plane unless they're vented....
My take on his post is that it would be mounted on the engine side of the firewall,
as that's where most FW-mounted Odysseys are located.
10534
Tue Dec 08, 2020 10:59 am
Experimental builders have been using them for years. Anyone heard of any actualized safety issues?
The data is out there as they sell a lot of batteries for aircraft.
2854
They now have a TSO'd version of their battery. Still working on STCs however... But meeting TSO should help in that process, and maybe even with getting field approvals?
JP256 offline
629
- Aircraft: Rans S-6ES
Zzz wrote:Experimental builders have been using them for years. Anyone heard of any actualized safety issues?
Okay, but as the OP noted, the company offers two different mounts......since this isn’t FAA approved, why is that?
10514
mtv wrote:Zzz wrote:Experimental builders have been using them for years. Anyone heard of any actualized safety issues?
I'm guessing the usual reasons... Cost to certify.
2854
Zzz wrote:mtv wrote:Zzz wrote:Experimental builders have been using them for years. Anyone heard of any actualized safety issues?
No, I meant why a fire protective box and a standard?
10514
Bump...
to see if the OP went ahead with the EarthX this spring...
I'm getting ready to move a battery to the firewall, mostly for cranking power. '76 180J w. Pponk.
Kevin
kevinmax offline
26
- Aircraft: 180J Skywagon PPonk
DHC2 Beaver
If anyone wants/needs the thermal battery box for the ETX-900, I have one that I'd be willing to trade for the standard aluminum box...
1:1 Scale offline
235
- Aircraft: Maule M4-220C
Kelly
Maule M4-220C
OP here. After some research, the switch simply wasn’t worth the 10ish pounds.
-Mounting a new box(or perhaps modifying the existing box),
-Installing a warning light in the panel
-Field approval hassle
-$700 for the battery
Or, order a new Odyssey for $185, and install it in 10 minutes.
Cranks our Pponk just fine
aqua offline
237
aqua wrote:OP here. After some research, the switch simply wasn’t worth the 10ish pounds.
Well said
1532
Fri Jul 23, 2021 10:18 pm
Awesome, thank you!
Kevin
kevinmax offline
26
DHC2 Beaver
There is 10 pounds of weight savings between EarthX and an Odyssey? Wow, that seems lie a lot!
2093
