Ive always heard that 380* and 1380* were pretty good targets...just add a 1
Thanks!dirstrip wrote:
I was taught peak EGT in degrees is a reference point not an actual hard number target that is transferable from one engine to another. Placement of the probe changes the temp reading but the value of the gauge remains in finding the peak EGT.....
shortfielder wrote:Hey Russ
Pm sent
Gary
260Driver wrote:Some good reading on the subject: http://www.avweb.com/news/savvyaviator/savvy_aviator_59_egt_cht_and_leaning_198162-1.html
BL, EGT's are relative.
When running LOP on my IO-540 I'll see EGTs in the high 14's/low 15's...I keep my CHTs below 400
Grassstrippilot wrote:EGT is a reference number. As a follow up to the posted article, here is an EAA webinar that Mike Busch just did in June that covers combustion theory and addresses CHT and EGT temps. Excellent presentation and worth watching. You don't need to be a member to watch them and there are a lot of good ones on there. Like others have said, 380 is what he recommends for a limit.
http://www.eaavideo.org/video.aspx?v=1678859198001
z3skybolt wrote:This subject....
...is getting to be like religion and politics.
Bob
Re: CHTs
Lycoming says to keep it above 150F and below 435F in cruise and below
redline 500F in climb. If it were mine I would be fine with 275-400 in
continuous cruise and below 450 or so in climb.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts
are hopefully helpful to you. Please use the information provided
responsibly and at you own risk."
Backcountry Tundra wrote:z3skybolt wrote:This subject....
Bob
Yes although everyone seems to be agreeing that god is LOP! would be nice to get more imput on this from bush lads here...guys like me tha constantly go up and down, change power settings, fly t/o-t/d at different alts, etc... Wonder if following the 380CHT is the way to go rather than trying to keep my EGT at 1370 (LYC IO-390 220hp).
Lets hear from you mountain folks!
Cheers, BCT
172heavy wrote:.... I run rich of peek on climb out and lean of peek on most cylinders in cruse, on climb out I will adjust my speed and mixture to keep my hottest cylinder under 370F, once at cruse altitude I go lean of peek, with the JPI I can find the sweet spot by monitoring my speed, fuel flow and MPG. For my engine I found that the sweet spot is balancing EGT on #4 and #6 cylinders, #4 is lean of peek and #6 is rich of peek.
hotrod150 wrote:172heavy wrote:.... I run rich of peek on climb out and lean of peek on most cylinders in cruse, on climb out I will adjust my speed and mixture to keep my hottest cylinder under 370F, once at cruse altitude I go lean of peek, with the JPI I can find the sweet spot by monitoring my speed, fuel flow and MPG. For my engine I found that the sweet spot is balancing EGT on #4 and #6 cylinders, #4 is lean of peek and #6 is rich of peek.
Do you have time to look out the window once in a while while you're doing all this?Holy smoke, glad I just have a little 320 Lycoming- I take off with full throttle, pull it back to 2500 for cruise-climb or cruise, and pull the red knob out "a little". Up higher, pull it out "a little more". I like to keep things simple.
With the wife, me and our stuff. Most Franklin powered 172s get 10 to 12 GPH around 152 MPH. We put around 130 hours a year on our 172, 130x$5.00=$650.00 to $1950 per year savings, not to mention the engine will last longer running it like this. People say fuel is cheap, but in ten maybe fifteen years what will I save? But then as you know pilots are all rich.
