Look at it like this, Amp meter flickers, then you lose all electrics, flaps, radios, in other words you lost all electrical, was the battery dead? If not, why didn’t the system run off the battery?
Have you ever attempted to start the aircraft with a dead battery and chattered the relays? Doing so will destroy the contacts in a relay in short order and may cause intermittent operation.
1. Check all battery connections, check each end on both cables
2. Check master relay, check connections, it may also be failing intermittently, causing the flicker
3. Check the power cable and connection points,
4. Check the amp meter and connection to buss.
If the battery was dead, then,
1. Loose alt belt, Bad alternator connections
2. Bad alternator or voltage reg.
3. Voltage regulator may have turned off alternator on overvoltage if master relay was intermittent or connections to are intermittent battery.
