If you follow any kind of aviation tech news, one of the hot (but novel) topics has been the electric airplane. Long dreamed of and always just out of reach, the concept of the electric aircraft powerplant is slowly becoming a more plausible reality with ever-improving battery technologies emerging.
For pure horsepower output, there is hardly a replacement for a gasoline or kerosene-- for now. Development is taking place in the LSA weight category generally. It's just cheaper and easier to develop on lighter, cheaper craft. There are motorglider hybrid projects out there that utilize high aspect ratio wing designs and are focused on a primary goal of efficiency, but what if the goal was simply to replace your current piston engine with a comparable electric of similar power output? It doesn't seem that outrageous when you consider that a Rans S7 or Just Highlander come in well under 700 lbs empty. We'll have to keep dreaming for everything else.
I don't claim to be someone who's thought about this for more than 15 minutes at a time, but for philosophical purposes consider this:
Pros:
- Zero local emissions (consider the "longer tailpipe" concept though, where the actual emissions from electricity generation might take place 1000 miles away at a coal-fired generation facility.)
- Equal power output at all elevations, temperature-related battery performance notwithstanding
- No mixture or fuel delivery issues
- Fewer controls (single thrust lever-- Basically, shares many of the FADEC pros.)
- Electricity to charge can be generated a variety of ways (dog in a squirrel cage, solar, wind turbine, burning stuff, nuclear, hydro, etc). Electric motor output is a great aggregator of possibly a variety of energy sources.
- Quieter (most aircraft noise comes from the prop.)
- No fuel to burn in an accident.
Cons:
- Immediate refueling not currently possible, time to charge required.
- Adjustment of gross aircraft weight not possible with fuel management.
- Short endurance (1-3 hrs currently possible)
For the sake of comparison, I choose to ignore the "what if's" or other catastrophic errors, because the same is possible with any IC engine, which in reality are a much more complex beast with induction and ignition and fuel delivery systems.
No matter your theory or opinion on the outlook for availability of petroleum, the concept of electric powered flight is valid.
Check these out:
There's potential for irony from the environmental angle, as so much of our domestic electricity is produced from gas-burning turbines, but I think the truly fascinating thing about electric power is that it can be generated so many ways. Once auto fuel and avgas become scarce, which is certainly possible in a Mad Max world, those Lycomings and Continentals are boat anchors.
I'm too in love with gas-powered things that go vroom to be a serious environmental crusader, but it never hurts to have an eye on the future. One bike ride along highway 26 near downtown Portland and your lungs will tell you that combustion emissions aren't something that can be ignored forever-- they're pooling in that corridor and I breathe them daily. Yuck. Bring on the nuclear power plants and electric motors.
