What should be on my checklist when discussing with the builder for options/pricing? Things I can think of with my current knowledge:
- After much debate I've decided to go with the
- The lightest 540's are parallel valve
- Narrow or wide deck? Does it matter? Update: I will specify wide deck.
- Remote mounted oil filter for accessibility
- Accessory case with 2 separate magneto mounts, no dual-magneto business.
- Engine mount style? Dynafocal type 1 or 2? Any advantage? This is often something that is just baggage with the case's particular brackets, and they can be changed but it's extra $$.
- I'll likely be going with some electronic ignition like the P-mag. Any considerations for that in the build process other than just not bolting some Bendix or Slicks on? Update: Likely going with integrated EFII. ECU controls ignition modules/coils.
- Probably just going ECI pistons/cylinders/pins/guides
- What things should I not specify and just consider my own problem? Prop governor, ignition, oil filter, plug wires, etc.
- Being the artsy guy I am, I need it to look cool. Is it okay to specify what paint i want on the case and that I need killer-looking valve covers? For this kind of expenditure, it better be.
- NEW: Alternator mount on the 540. I just learned of this, that the alternator can be mounted in different locations on the case. What's best?
Remember this is about my discussion with an engine builder for the order, not necessarily a carb vs injected vs high compression debate.
