Backcountry Pilot • Engine roughness mid range
This subforum is meant to organize Skywagon-related topics.
3 posts • Page 1 of 1
Hi All,
I have a 185 with a io520D in it. I am starting to notice a little shaking/maybe engine roughness when I move the power through 19-21 inch manifold pressure. If I’m in that power setting it will sort of be on and off shaky/rough. It’s pretty minor but I definitely notice it.
I have GAMI injectors and I noticed that if I’m descending/cruise/etc with it *leaned* it doesn’t seem to do it. I had it at 19” entering the pattern and it was smooth then as I enriched the mixture it got shaky/rough.
So maybe it’s just a bit rich in the mid range? Set that way to keep the temps down?
I have an EI monitor but it’s starting to fail. Shuts off, Erroneous indications sometimes, etc but temps seem pretty normal when it’s working well. Maybe my number 5 is a little cooler than my others sometimes but not all? I have gills.
Maybe I need to do a mag check in the air?
Any ideas? Incorrect fuel flow setting? Bad injector? Anything I should look for?
Thanks!!
Lettucelord offline
Aircraft: C180
Re: Engine roughness mid range
How are you going to diagnose engine problems with a flaky engine monitor? Seems like that should be first on your list of things to fix. If you get a newer one with a data logger you can go back and look at what happened in much finer detail.
akschu offline
Contributing author
Aircraft: 1949 C-170
20?? 4 place Bearhawk
akschu wrote:How are you going to diagnose engine problems with a flaky engine monitor? Seems like that should be first on your list of things to fix. If you get a newer one with a data logger you can go back and look at what happened in much finer detail.
It’s at the top of the list! Just started acting up last week.
Lettucelord offline
Aircraft: C180
