Backcountry Pilot • Experimental, Liberty 181
19 posts • Page 1 of 1
Anyone ever heard of this one?
Thanks, GT
M6RV6 offline
Re: Experimental, Liberty 181
M6RV6 wrote:Anyone ever heard of this one?
Thanks, GT
Never heard of it but a search turned up this info, supposedly the company that sold them. No website listed.
Associate Air LLC, Aircraft - Mfg - Dist - Whol in Cave Junction, Oregon OR
Company profile for:
Associate Air LLC
115 Airport Drive
Cave Junction, Oregon ( OR) 97523
Phone : 541-592-6601
Primary Category : Aircraft - Mfg - Dist - Whol
dirtstrip offline
As I recall, the Liberty 181 was supposed to be a homebuilt version of a C180. A guy named Bud Morrison (?) from around Kelso WA built it & supposedly marketed a kit version. Looks like he sold the whole shebang to someone in southern Oregon.
I just googled Liberty 181 & found one for sale in BC on Barnstormers for $50K. I think I'd stick with the real thing.
http://www.airliners.net/photo/Morrison ... 0845738/L/
This looks interesting, however it is certainly no copy of a 180. This photo may give the wrong perception, but it sure looks like the axles are way too far rearward. From that photo I'd guess one tap on the brakes and you're on your way to the prop shop.
Looks like the hangars on the east side of Arlington WA airport to me.
Then there's this one: http://www.libertyaircraft.com/ but I think that's different than what you are talking about.
... and that one started as this one: http://www.europa-aircraft.com/monowheel/ Got a 'merican engine and three wheels when it came over here. The original was kind cool.
Yellowbelly offline
Maule M-7-235C
I'm lost
but I'm not afraid
Doesn't look like any hangars at Arlington that I've ever seen before, & I've been there lotsa times. The MLG does look pretty far aft, esp considering there's an O-470 under the hood. The lower cowl has a wierd line to it, otherwise the airplane isn't too bad looking. But you;re right-- it's no 180 replica. Note that I said "version" in my earlier post, not copy.
I looked at the red ,white,and blue one , several years ago in mind to purchase. Most of the plane was composite panels. Wing skins, and fuselage covering. Don't remember what structure was underneath. I was set to buy it , but an older wiser friend talked me out of it. Plane had some unique (good) ideas. One I remember was the instrument panel was hinged at the bottom to fold down to access everything easily. Did not fly it, as I think the designer was not legal to fly. I think it was medical problems. If I remember correctly he also designed and built a few composite floats which I went to look at for a Stinson.
flathorn offline
Thanks For all the help guys!
Digging a little deeper into it, all the parts are either 182 or 180, with Huge I beams for spars, Huge flaps and ailerons, 56 degrees on the flaps, screw jack on the tail, engine mount,engine,prop all off 182. 125 cruise and ridiculous slow if hanging on prop.
Has some good ideas!
Always fun to look. Yea I know it's the only one out there. And it is not a 180, but I very seldom go down the center of the road between the lines!!
GT
M6RV6 offline
M6RV6 wrote:Thanks For all the help guys!
GT
Looked like constant chord wings to me
Several years ago I went over to Illinois Valley (Cave Junction) to look at a Cessna part that the Liberty guy had for a 180 project I was working on. Glanced at the Liberty while I was there...... From what I remember, the fuselage was mostly fiberglass/composite (could have been aluminum skin, was a few years back) and I kind of remember a tube frame around the passenger compartment. The interior was very large with lots of room. The wing was typical dual spar and rib construction with a thin composite/fiberglass "skin" bonded to the ribs. He had two sets in his shop. Was an interesting looking aircraft. I am not to fond of the parallel struts though, seems to me that they would get in the way while loading.
Brian.
Brian-StevesAircraft offline
Pavement scares me..........
Dad's SPOT page
EZFlap wrote:http://www.airliners.net/photo/Morrison-Liberty-181/0845738/L/
I'm the one who took that photo on Airliners.net linked above. It was taken at Pearson Field in Vancouver WA (KVUO), in 2005. The airplane had been based at Woodland (W27) for years, then it was at Pearson for a while. According to the FAA registry it was de-registered in 2008 and exported to Canada.
Pilawt offline
I stand corrected, sorry. I took a ride in a 170 out of Arlington a couple of years ago and the little pads in front of the hangars looked like that. I was too @($*% stupid to realize that the other hangar apron pads in the area might look similar because of the weather or some other factor. D'OH #-o
This airplane is blast to fly and is extremely easy to land. The 0-470 makes you fell like superman and the 40 foot wingspan with its 19 1/2 feet of flap lets you land a 40 mph. If you want to bump this plane on its prop you will need to lock up the brakes and shove the stick forward.
Flythenorth offline
flathorn wrote:I looked at the red ,white,and blue one , several years ago in mind to purchase. Most of the plane was composite panels. Wing skins, and fuselage covering. Don't remember what structure was underneath. I was set to buy it , but an older wiser friend talked me out of it. Plane had some unique (good) ideas. One I remember was the instrument panel was hinged at the bottom to fold down to access everything easily. Did not fly it, as I think the designer was not legal to fly. I think it was medical problems. If I remember correctly he also designed and built a few composite floats which I went to look at for a Stinson.
Do you know what happened tho the floats? I have been trying to find them for years.
Flythenorth offline
Its funny this thread popped up! I was just browsing the British Columbia kijiji for airplanes (as i do regularly) and there's a Liberty 181 for sale in Northern BC... I don't think I'm supposed to put links to for sale items on here but I'm sure a little google search would turn it up.
Parker77 offline
hahaha now that i read a little closer, does that airplane happen to belong to you Flythenorth? Great looking plane.
Parker77 offline
Parker77 wrote:hahaha now that i read a little closer, does that airplane happen to belong to you Flythenorth? Great looking plane.
Ya! thats my girl. I'm going to miss her but she needs to sell.
Flythenorth offline
Flythenorth, is Larry Frey still kicking around Vanderhoof? Nice 181...what are you getting once she goes? Cheers, BCT.
Backcountry Tundra offline
Larry Frey is still in the area. He's been flying out of PG for the past 10-15 years. He was flying a 1900 and now he's flying a Conquest for a corporate company. In regards to the 181, their is a small business that I would like to buy with the money, but if I sell the Liberty after I buy this business, I'd like to get a smaller bush plane.
Flythenorth offline
