clippwagon wrote:29singlespeed wrote:clippwagon wrote:Another option to consider is the purchase of a "cheaper certified airplane" with the ability to go experimental as time and money permit. The Piper shortwings are famous for this and allow a ton of options for improvements/changes including some that would make it experimental. There is also a lot you can do with them while keeping it certified (i.e. changing the 0-235 for a 0-320 in the pa-16, or installing a second wing tank, etc.). They are fairly easy to maintain and there is a ton of support for them on the shortwing Piper forums and you can get into a decent bird for $25K or less. Fun to fly as they are, and fun to modify as you see fit!
CW
Whats it take to change one to experimental?
Good question. I'm not familiar with the process though I know it's done. I'm sure someone may be able to add some insight. However, there really is a lot that can be done (by you with an A&P ready to sign you off) while remaining certified. A few more examples are: bush wheels, wing tip mods, landing gear mods (?), climb prop, and as mentioned above a right side fuel tank and bigger engine. I believe you enter into the experimental world when you do things like add pa-18 wings and stretch the body etc.
That being said, the pa-16 I fly is close to stock and very capable and a lot of fun. I cleaned up and re-covered the wings last year in my shop at home and went through the whole plane nose to tail giving me a good understanding of how simple the thing really is. The last annual was just over $300 as an owner assist and took about a day to comlpete. It's a great fun way to get in the air on a budget and worry about the other stuff as you can. Maybe when the engine is run out I can consider an o-320???...Then again, maybe I won't want to!
CW
No, you CANNOT simply take a certified airplane and turn it into an Experimental/Amateur Built airplane with a few modifications (or even with a BUNCH of modifications). Don't believe me? Check with EAA on that.
This was done years ago in some cases, but the FAA slammed the door shut FIRMLY on this sort of thing, based partly on the 51% rule.
Now, you CAN convert a certified airplane to Experimental/Exhibition category, but that means every year you have to ask/tell the FAA which "exhibitions" you're going to appear at this year, and virtually all other flying is restricted to local area proficiency. Look on Barnstormers--there's a Cessna 170 with a turbocharger on there in this category that the guy's been trying to unload for months.....and it probably won't happen. Nobody wants an airplane in that category, unless its purely an airshow performer or maybe a warbird.
There seems to be a number of folks out there who assume you can convert a certified airplane to an Exp/AB airplane, but it's simply not possible these days.
And, if you're buying an EXP/AB airplane, bear in mind that every part may in fact be new, but some of those parts may in fact be hardware store stuff......and that may or may not be a bad thing, depending on the role of that hardware store stuff. Problem is, how do you SEE that stuff during a pre-buy?
Buying a flying Experimental Amateur Built airplane is a SERIOUS exercise in trusting your fellow man to have done things right. Many have, and there are some superb examples out there.
There is some real junk and a lot of "better ideas" as well.
It can be done, but be careful. Of course, somewhat the same goes for certified aircraft as well.....
