Backcountry Pilot • FAA approved Carabiner? Shackle?
24 postsPage 2 of 21, 2
Re: FAA approved Carabiner? Shackle?
denalipilot wrote:Whee,
In my past looking, it’s the sewing that pops up all the roadblocks. Seatbelt companies have too much at risk to help you with your project. Gear repair shops can do commercial-grade bar-tacking, but you won’t come away with a certified label. I assume that’s why Atlee and others provide a metal tri-glide buckle to customize seatbelt ends. Less elegant but more universal.
Good luck,
-DP
Thanks DP. I don't need a certified label on the belt. Strange how works. Would just have a local gear repair shop sew on the new ends.
Dogpilot, I value your opinion and appreciate it when you share your experience/knowledge. My installation was inspired by the Atlee Dodge jump seats for Cessnas. That STC uses the same track and single stud fittings I plan to use.
whee wrote:.... Sewing on new "clip" style ends is probably the better way to go and the belt assemblies DP posted from ebay are inexpensive enough that I can buy a few belts and salvage the ends from them. ....
Are these simple lap belts, or shoulder harnesses?
Spruce sells the clip-on fittings, p/n 442868, $30 each
https://www.aircraftspruce.com/catalog/ ... rdware.php
as well as a variety of lap belt sets for $75 and up per seat.
https://www.aircraftspruce.com/categori ... belts.html
Dunno if they sell them with one bolt-on end and one clip-on end,
but you could buy one of each, then mix-and-match them.
My belts are all 4-point harnesses with rotary buckles.
What about these?
TangoFox offline
Keep the Greasy side down!
