This is more from my ag aviation background but I feel that this may be pertinant to some of you here as well.
The FAA is soliciting comments through February 4, 2011 regarding an AC regarding the prosposed "suggestion" of the marking of met towers. These are the little 196', single pole, guy wired structures that are very portable and nearly invisible. With the proliferation of wind energy west of the Mississippi these little guys are popping up all over on buttes and ridge tops. A real danger to those of us out working down low and even for those of you that end up out playing around in the middle of nowhere down low.
Our beef with the proposed AC is the "suggestion" to mark them. We would like to see an actual law or rule to manditorily mark every one of them. If you see fit use the link below to read through and make comments on this issue.
http://origin.www.gpo.gov/fdsys/pkg/FR- ... -33310.htm
And be careful out there playing, these things are INVISIBLE and we unfortunately had the first documented fatality of anyone, an aerial applicator, due to one of these towers just this week.
Thanks,
G-
