Backcountry Pilot • Favorite cleaner for belly slim?
38 postsPage 1 of 21, 2
What's everyone's preferred cleaning agent to get the slim/oil residue off the belly? I've only washed the belly of my plane once since I bought it and it sucked. Surely there is something that won't hurt the paint but will cut the grime without extensive scrubbing. I used purple power last time and turned a bright blue chami-scrubber black in an instant. From there, I just spread the grime around like butter on toast. With dirt particles mixed in, that can't be good for the paint. Trying to avoid that again. Thanks in advance for any advice.
Nushi offline
Aircraft: 1960 Cessna 182C
Re: Favorite cleaner for belly slim?
Buddha Belly from Plane Perfect is great. I think there's a BCP discount as well. Their other products are excellent too.
Edit: https://backcountrypilot.org/forum/fs-p ... lies-16338
I just use the honda motorcycle polish from the dealer. It's like $5/can, works great.
hamer offline
I used to use PJ1 air filter cleaner for everything degreasing-related. Fairly mild but will cut through most oil or grease based gak,
GoJo without the grit and washes off with water.
Moss farmer offline
Av gas works great!!! No joke
AKT
Extreme clean works great. Envirosolve is also good but more expensive. Formula 409 will discolor any bare aluminum and it will need to be republished. A rag with some avgas on it works great, but your insurance company will not approve if they find out.
Dale Moul offline
Dale
Gravity Strikes Again.
I've seen mineral spirits in a pump sprayer used before.
jcadwell offline
As AKT says, Av gas is the best thing I've found over 25 years of ownership. Does not take much and do it after no more than a few days worth of belly gunk.
MW
185Midwest offline
Aircraft: C-185
Moss Farmer; agree- GOJO without pumice. Been looking for the holy grail of belly cleaners since the early 80s, GOJO, wipe on with rag or even by hand, let set a few minutes and wipe off or rinse off with hose if you have water. Actually (no shit) cleaned the exhaust stain off my turbo 210 right cowl flap that is located directly behind exhaust. AND took no paint with cleaning and very minor scrubbing.
Jack
flyingjack offline
Aircraft: Husky/T206H
Simple Green Aircraft Formula (aluminum safe ) .
umwminer offline
Aircraft: Citabria 7gcbc ,
Someone else.
Barnstormer offline
I bought a bottle of this for my 180's annual and it works AMAZING. Plus it's lead free. Aero Cosmetics Belly Soap
https://www.aircraftspruce.com/catalog/ ... 20Products
akaviator offline
Aircraft: Cessna 180
Avgas works for me!! The Stinson with the Franlin liked to spit oil. I tried the budda belly and it kind of works but the avgas takes off the slim!!!
RC5280 offline
Aircraft: 57' Cessna 180A
90% Mineral Spirits, 10% 100LL in a spray bottle.
DBI offline
Agree with Moss farmer and flyingjack.
Gozo original formula with no pumice.
I’m told the key ingredients are Varsol, detergent, and gel.
Perfect. Varsol dissolves the oil, detergent releases the Varsol/oily mess from the paint, and the gel helps the product to stick and resist gravity so it’s not running off before the job is done.
Varsol is the local trade name for mineral spirits or white spirits.
Pinecone offline
Oil Eater, mix 50/50 with water in a spray bottle, spray on, wipe off, easy peasy.
Hafast offline
eOx Aircraft Cleaner
Cleaned surfaces become slightly antistatic and corrosion inhibitive for up to 4 weeks.
https://rpm-technology.com/product-line ... t-cleaner/
https://www.aircraftspruce.com/catalog/ ... gallon.php
Aryana offline
Aircraft: 1955 Cessna 170
Scrubbing Bubbles.
Pukingdawg offline
Aircraft:
RV-4
AvGas, or any kind of gasoline. Cheap and works like a charm. DON'T SMOKE!
NunavutPA-12 offline
