YELLOWMAULE wrote:Actually, instead of going into details about the type of unauthorized repairs that get done, let's hit on prevention
Well, as the author of this ill-advised thread, I appreciate the direction you just took it, YellowMaule.
Beside the rolling run-up and the gradual throttle application on takeoff, another good trick for STOL takeoffs is a J turn. Assuming you have to back-taxi to your takeoff-starting point, you can carry some speed through your turn at the head of the runway and then you are already accelerating when you complete your turn, pointed down the departure runway. Also helps to avoid any of that standing-on-the-brakes, rock-sucking agony that we've all witnessed.
-DP
