AEROPOD wrote:hotrod180 wrote:When the t/w is locked, there is somewhat less rudder travel than when it's unlocked.
ABSOLUTELY NOT TRUE! This is on of the biggest misconceptions about the tail wheel lock and it just isn't true. I wouldn't own a 185 without one and I've installed one on a bunch of skywagons. I don't understand the aversion to something that helps keep your tail wheel aircraft pointed straight....
EZFlap wrote:Is it not appropriate in this thread to discuss tangential solutions, like aileron gap seals, that might potentially assist with improving the roll rate on the R/STOL equipped 185?
wingnut185 wrote:Will VG's give the Robertson STOL the roll rate of the stock wing?
I understand VG's will help the roll rate, but will it be as good as stock? That is my question. Will VG's give the Robertson wing as effective ailerons as stock? Sorry MTV, I have considered disconnecting it.
