soyAnarchisto wrote:My C180 POH says retract flaps as soon as practicable and to climb without them. 1956....
aktahoe1 wrote:I leave the flaps extended as long as practical for the given departure. Getting up and over a 150-300 foot obstacle I leave them in until clear. Departing a place with no hazards I retract them much sooner. Departing JC I leave them in until I'm over the tree tops mid field. I also don't go straight down the runway. I climb high and fast and skirt to the right over the trees by mid field allowing me to make it back t the runway quicker if needed. Flaps extended help this. Retracting them sooner would mean you must go further down the runway for climb out.
AKT
DENNY wrote:I normally always use flaps for takeoff. Lower them if I am in ground effect to help gain more speed and use that speed to climb out. I still have the flaps(money in the bank) and will use them if needed. If I am at 30ft AGL in the mountains and want to climb over a ridge I will some times add 1/2 flap to give me some more lift. If you can keep CHT temps under control a climb with partial flaps should be faster than without.
DENNY
but I always found the climb with 10-20 degrees flaps felt much better than without. Probably a little harder on the flap tracks and mechanisms with the higher power settings on takeoff and climbout, but worth it when you need to climb like a scalded cat. Sure you're slower if the donkey quits, but the stall speed is lower too and you're closer to the area you just departed from in case its the only forced landing spot around. One way to look at it anyways...bart wrote:....I don't have my wagon anymore.....
Headoutdaplane wrote:The question for me is when do I not use flaps. Got flaps for takeoff, climb, cruise (just a wee little bit, depending on cg), steepish turns, and landing.
