Backcountry Pilot • Float parts, Step for boarding
6 postsPage 1 of 1
I installed the Full Lotus Floats on my RANS S-7 and will be doing the W/B this weekend. While having to replace all the break lines for the amphib gear, I realized my short legged stature that I could benefit from a step mounted to the float rigging. Basically a piece of angle that I see on most floatplanes for a foothold that attached to the float struts. It has closer to a 45 degree angle verses typical 90 angle material. Does anyone know where a person can a length of it?
Experimental, so doesn't have to be PMA. I'm thinking I got some from PK about 20 years ago that I had put on the Champ I had at the time.
Re: Float parts, Step for boarding
I've bought that from Kenmore in Seattle. It wasn't all that expensive as i recall.
Fraser Farmer offline
Aircraft: 1977 Cessna 185
Zzz wrote:Maybe something like this?
https://aircraftextrusion.com/aircraft_ ... S60-30186/
YES!! Thanks Z!!
Fraser Farmer wrote:I've bought that from Kenmore in Seattle. It wasn't all that expensive as i recall.
I'll give them a call also. Thank you!
Eddie Peck at Peck Aero in Nova Scotia
Jim
Tcraftf21 offline
Aircraft: Taylorcraft F21
6 postsPage 1 of 1
