I posted the following in the other thread as someone cross-posted my post in this thread over there and I replied. (I'm getting SO confused!)
Re: Aggressive LOP power settings -540
mtv wrote:
A couple points:
And, of course, Continental gave bad information on fuel flows.
You can run your engine however you like, but I think there are some valid reasons not to lean these engines aggressively at high power settings.
And I am a firm believer in running many engines LOP, as long as it's done intelligently.
Well put. Traditional ROP recommendations put cylinders right smack in the middle of the "red fin". If you're going to run rich, the new consensus of the really smart guys (not me), is to run very rich, like 120d ROP.
The Red Fin.
My "other plane" is a Cirrus SR22 with a normally aspirated IO550 with GAMI injectors. On the Cirrus Owners and Pilots Association Forum (COPA) over the eight years I've been active, there has been a lot of discussion and now with a large fleet (around 6,000 Cirrus out there) and millions of hours and a lot of data, it was found that a lot of the turbonormalized SR22's were needing cylinder work at 800-1100 hours. When they first came out (2007) the sales and marketing hype was a 200 knot plane. Too many were operated at 85% power, basically WOTLOP (wide open throttle, lean of peak).
At the same time, the majority of the fleet of normally aspirated SR22's, like mine, quietly were making it to TBO and beyond (2960 hours in my case). The takeaway was that the NA birds were being run mostly from <65% to 70% power. (For example, 90% of my SR22 flying is cruising point A to point B WOTLOP at 10,500 to 12,500, where it can't make over 65%.) Probably 90+% of the Cirrus operators run lean of peak the majority of the time. The difference was the TN ships were just being run at too high a power.
With the low altitude type of flying many on this forum enjoy, the conclusion would seem to be that it would be a good idea to pull the power back for LOP ops. One of the reasons I bought my modified 1964 182-G seaplane (now a backcountry plane) is that it has an IO550 with GAMI injectors and a JPI with individual EGTs and CHTs so I can run it like my CIrrus engine. The difference is that down low I pull it back, to say, 21" MP and then lean to about 20d LOP.
Oh, BTW, with this setup I lean "brutally" for taxiing and ground ops.
Pierre
