Sat Dec 29, 2012 10:23 pm
Well, there are several routes, I normally go up the coast. The problem with that is that no one really knows what the weather is along the route. Every time I get a briefing I shake my head, because the briefer talks like they know what it is doing, but the fact is that the reporting points are so far apart that there can be much different conditions in between. Also, if you have to put down along most of the trip it will likely end up badly, there is a lot of untamed country out there. If you are prepared for that it is the shortest route, and will save a bundle on gas and time.
I always go direct to KTN or JNU If the winds aren't too bad. If you are on floats it would be wise to have a couple cans of gas to stop and put in if the winds are bad. That is assuming you carry 80 gal, you will need that much on a good day.
Good luck, it is Gods country up there, I try to get there every year if possible..............
