Backcountry Pilot • Flying & owning a Maule Long wing vs Cesna 180
176 postsPage 8 of 91 ... 5, 6, 7, 8, 9
Re: Flying & owning a Maule Long wing vs Cesna 180
Zane,
Short and sweet :)
mountainwagon offline
mountainwagon wrote:Here is an opinion and experience that most would not or may not be able to do. In doing it this way you learn more about the aircraft and why you wanted it and why you may not need it.
I was able to own a long wing M-7-235. I owned three other Maule's also. I owned a Cessna 180H and several other Cessna's also.
I was able to have the Long wing parked next to a 180H and jump from one to the other and fly them both the same day.
I was able to experience the build up and repair and finding parts and see how it's made and put together on the M-7-235.
I was able to experience the build up and repair and finding parts and see how it's made and put together on a 180H.
I was able to sell both and experience the market for them.
I really loved Maule's and started " Just buy a Maule" years back. A maule is not a 180 and never will be and they are different in many ways and would take a lot of typing to spell it out. A Cessna 180 will never have a few things a maule has and you have to have both and build up both to know what I mean.
For the cost of either one needing the airplane or just wanting one will come into play. Both aircraft flew different in there own way's. A maule is like a Mr. potato head, same basic fuselage with different wings, controls and engines. A Cessna had different models and all models had various changes throughout the years. The 180 being one with a lot of changes you may not know about until you build one, find parts for one do research on one and fly a so called early light one to later H,J,and K models. I would stay away from the first year's of the 180, the cost is not much different and there are benefit's in later 1950's models when you get down to it, Don't settle on either airplane do your research.
Final conclusion for the value end of it.
22 year old Long wing Maule M-7-235 over 1000TT Really nice airplane sold just under 90K
50 year old Cessna 180H just over 3000TT Really nice airplane sold just over 100K
So, which one would I choose? :roll:
Thanks for posting this. Obviously you chose the Wagon. [emoji6]
What year is your current airplane?
Crzyivan13 offline
Aircraft: 1957 Cessna 182A
I think a big determinate is where are you going to be keeping the airplane. If not in a hangar I think the Cessna has a large advantage due to not being fabric.
Mountain Doctor offline
Aircraft: Maule MXT-7 180A
:roll: .
mountainwagon wrote:Here is a unabridged version :shock:
Had a lot of airplanes a lot as in dozens. I am not Waldo Pepper. I fly, feel and fix. Just some things about the two aircraft.
First off I give my hat's off to B.D Maule for doing what he did. There are a lot of changes in the Maule models throughout the years. Some times changes are not for the good. Flying a m-4-220 around wanting more out of it. You don't read much about a Maule when one owns one how it may be. kind of like a first girlfriend. One thing to think about is why Maule went away with the long wing. It may be it had adverse yaw and aileron control was weak, maybe that is why the A model shortened the flap and added it to the aileron. Some guys ask about auto pilots on a Maule WTF. Maybe because they noticed it hunt's in the air. kind of like a v-tail fix with a yaw damper. Maule's are small airplanes. They are ugly except the M4 round tail. The exhaust system sucks ass, the fuel system is a system in itself. They are a one off model and not a lot of options for propellers etc. Hard to get in and out of when you get old and have to duck under the wing. They need more AOA and putting about 10K out for extended gear and bush wheels will fix that but it 10K and then be in the air? No thanks. Parts are not cheap anymore and getting them can be a hair puller. Not a lot of used parts on the market or over stocked parts from dealers. A lot of unknown out there on them by owners. They are quiet with only a 81 inch prop turning 2400 rpm and the exhaust is not beefy sounding. Be good for not pissing off locals like a 88" 180 prop. They do fly nice if you learn to fly them. They will land short and take off short. Load it up and that changes. The side cargo doors are real nice. They are a slow airplane, Not a M-4-220. Tubing and fabric can cost you if it comes time for a recover. They are the closest certified aircraft to being a homebuilt. You can build most parts if you had to. I don't think they will hold there value like a 180 has and a new one will fly like a old one. Would I get another one, sure not a M7 long wing though.
Finding parts for a Cessna 180 can be a chore and cost you some $. The good news is there are parts out there. It takes a lot more time and tooling to do sheet metal work and to do it right and nice. There are a lot of changes with the 180 through out the year and for the price of one being a 1953 or a 1968 I would go with a later one. Even a late 50's had changes worth passing up the first and second. That is where my don't settle and do the research comment comes in. Sure a lot of guys have them and some have been modified. I would rather just get one that Cessna did all the R&D on and move on with my mods. Also Cessna did not use the name sky wagon until 1969 for thew180 so any older than that is just a old Cessna 180 as in 60-50 years old. They fly nice. Some are fast some are slow. Most have been bent to shit and fixed. They are easy to get in and out of. They are tall and big looking. You can do a lot with engine and propeller mods. Stall mods, gross weight, wing extension mods and every thing else to pour money into it. They sound real beefy and can really piss off some ground pounders with a 88" prop. After a while you have to ask yourself do I really need this or just want it. Could be a ego thing for some. The one's with the hand on the prop and cock pose on the ramp or the one calling sky wagon on down wind in the pattern and it is a old 180. For what they are and the price they bring I think they are over priced. I am glad I sold mine while the money is still good in this country. Would I buy another one, sure not for the price they are though.
If I had to choose a M7-235 or a 180. It would depend on what I wanted to do with it. If I had Metallica rocking in my head sets and was going to take myself or one more and a light load to the motocross track of the airways I would go with a Maule. If I put some Rush or Led Zeppelin through the head sets and loaded up the wife and kids for a long flight to get where ever I wanted I would get a 180H.
I would get a late 50's 180 if the price was right. I would take a M-4-220 any day over any other Maule out there. Just my choice and favorite Maule. I would also take a 170B or another AL-3 American Legend for a LSA. Can't beat a good old 182 or the Cadillac of the single Turbo 210.. I sold four airplanes this year. Been around airplanes all my life. Found out after a few wrecks I never let anyone fly me. I don't want a airplane older than me 1964. I have had over 53 airplanes, never did a pre buy on one. Sold over 60 airplanes. Met and talked with some of you. Met and lost some great people. Never seen such a close nit and sincere and honest group as pilots we are.
At this time in my life with changes I have no airplane and have moved on to another chapter to explorer in life with all this extra $ :roll: .
You need a radio show, man. 8)
mountainwagon wrote:....Could be a ego thing for some. The one's with the hand on the prop and cock pose on the ramp or the one calling sky wagon on down wind in the pattern and it is a old 180......
I get real tired of guys saying "Piper 123" (or just the tail number) when there's a Pacer a Cherokee and an Apache all in the pattern and you can't tell which one's reporting what. I say "blue-and-white skywagon" on the radio because I want people to be able to tell which airplane is me-- the 180 and not the three or four 150/172's in the pattern. And FWIW I may have my hand on my cock sometime, but it's for pleasure not posing. :wink:
I'd never considered that using "Skywagon" in the pattern in my lowly old 1959 180 would offend anyone. Live and learn! :D
"Yellow and white Cessna Taildragger" is probably better anyway.
Opinions Vary.
A couple of comments re mountainwagons Maule description. There are in fact 6 different props available for the 235hp Maules.
The longwing was temporarily dropped because of production flow. Maule was building too many different wings so decided to settle on one, which became known as the universal wing and is only 9" overall shorter than the longwing, The longwing will likely be offered now in response to demand.
To gain AOA, one can fit extended gear to oleo models at $4000, or, large tyres between $3 and 4000. You don't need both.
A Cessna aileron is nearly $6000 and a Maule aileron nearly $1000.
I don't know speeds of the C180s however a 235hp Maule can do 160mph TAS in stock configuration and a 260hp 167. The turbine M7 added just for grins can do 195 but is airframe speed limited.
Its a bit of an apples/oranges comparison as Cessna and Maule could not be further apart in their lives and historys.
One model of Cessna production is over 6000 whereas 42 derivatives of Maule are only 2600, with less than 500 M7s.
Just felt the need to add to mountainwagons description for those reading.
maules.com offline
That is good to know about getting the option to buy a set of long wings from Maule. The propeller comment was toward Maules. Options for the engines on say 180hp or 210. Not many and not many on the used market. Hard to find a good used 81inch C224 for the 235hp. Parts are also for the used market. I would never buy a $6,000 aileron for a 60 year old airplane and wonder who would. I bought used serviceable ailerons for a Cessna180 for $500 each and lift struts for $750 each Plenty around if you look. Last set of sealed struts from maule shipped was around $2,000 I here it is more now and how long will it take to get the parts from Maule???? I did not want to go into the parts deal to much due to most guys who bend them up pass the buck onto the insurance company and move on. The point of aoa was that to gain it you have to spend thousands of dollars for rubbers and thousands for extended tubes. Porn is cheaper than that! :shock: Spending the money for a set of long wings will be a hard one to swallow for it will still just fly through the air as it was meant to do. It is rare to find a fast Maule. That is one reason I liked my M-4-220 it was fast. I also like mph knots are for sailor's. Indicated and ground speeds on the gps. Absolutely banana to grapes type aircraft. They both fly and both work in different ways.
Hello Backcountry Pilots,
A snowy day here so I thought I'd chime in on the discussion. A Maule is somewhere right between a Super-Cub and a Cessna 180. My 210HP M-4 is one of the lightest Maules. The thrust to weight combination is impressive. I bought a very low time Maule w/150 SMOH & 50 hr Prop for $42 K. You can't touch a Super-Cub or 180 for that much money.
Hell, some of my best friends fly Cubs & 180s!
My Maule is slower than a Cessna 180, but faster than a Cub. The cargo door is a great option too. As far as flight characteristics go, it can bite you if you are not competent and current in the airplane. Maule performance is legendary.
Happy Thanksgiving!
James
Clear Creek, Idaho
[img]http://i230.photobucket.com/albums/ee15/jamesp1961/DSCF6819_zpsea3dac48.jpg[img]
[img]http://i230.photobucket.com/albums/ee15/jamesp1961/DSCF6821_zps03afa676.jpg[img]
[/img]http://i230.photobucket.com/albums/ee15/jamesp1961/20151003_151704_resized_zpsmv9ozeds.jpg[/img]
[/img]http://s230.photobucket.com/user/jamesp1961/media/Maule%20%20Scanlons_zpsunar4t9d.jpg.html[/img]
Super-Maule offline
Super-Maule wrote:Image
Fixed your pics, James :D
Oregon180 wrote:I'd never considered that using "Skywagon" in the pattern in my lowly old 1959 180 would offend anyone. Live and learn! :D
Imagine flying a 59 Skylane with the little wheel on the tail and calling it a Skywagon. :D
Terry offline
The horror! [emoji15]
Hmmmm.... What about the tricycle skywagon?
behindpropellers offline
Aircraft: C206 & Cub
THANKS!
Super-Maule offline
"TriWagon"
Crzyivan13 offline
TriWagon
akflyr182b offline
I like that!
maules.com wrote:.....A Cessna aileron is nearly $6000 and a Maule aileron nearly $1000.....
Years ago, a mechanic I know got the job of repairing a ground-looped Maule. One of the bent pieces was the RH aileron. He told me he couldn't believe how cheap a new aileron was from maule vs the same part from Cessna. Later on, he told me he couldn't believe how much re-working it took to make that aileron fit on the airplane. So maybe the moral of this story is that sometimes you get what you pay for,
