EDIT: I should be clear that this is a brand new engine on a stand that I have built.
I'm about to bolt new cylinders onto my IO-540, effectively closing up the crankcase. It will likely sit for a while before it's first run. I'd like to do some corrosion prevention for storage.
Cam lobes are manganese phosphate coated from overhaul. Cylinders are new and black oxide coated. I'm primarily concerned about exposed steel on the crank and rods. Federal Mogul Sealed Power assembly lube was used on all journals and bearings.
I've heard of guys pickling engines by just filling them to the brim with oil. Is that actually the best way?
There are products called fogging oils that come in an aerosol can that are formulated to coat internals without running off. Just wondered if anyone had used them.
I'm tempted to use the same fogging method I used to apply Boeshield in my 170...garden sprayer with high pressure fogging nozzle.
Curious what others have done. Engine will be stored in heated garage.
