Mon Dec 10, 2007 11:32 am
I'd drop in & talk to Steve's Aircraft over at White City, they do alot of shortwing Piper work and have also been involved with Producer style airplanes. They posted something a while back on sc.org about a friend of theirs who built a stretched Pacer with big Cessna style Fowler flaps, it looked pretty cool. Lotsa Producer/Bushmaster info on the sc.org site, BTW.
If you;re gonna go the STC/field approval route you can keep the n number, etc. If you're gonna register as an amateur-built experimental, lose the n number, airworthiness cert, etc. Maybe you can sell them. FAA is really starting to frown upon builing a homebuilt from a factory airplane. You might wanna talk to the FAA inspector and/or DER who you would be working with to register the thing, and get their imput before you get too far along.
You can get more performance out of a Pacer just by making it as light as possible, and adding VG's, tips, flat prop, fat tires, etc-- all STC'd or (somewhat) easily field-approved. Eddie Trimmer up in Alaska does a lot of trick Pacer work.
Eric
