Backcountry Pilot • SOLD: PA-22 Pacer Extended Wings and New Struts
Historical archive of past FS posts that have been satisfied or marked "SOLD," intended to provide reference for pricing and parts availability.
1 postPage 1 of 1
I have some extra Pacer parts available.
Wings are extended with Svenn’s “modified wingtips” STC to square them off and then some. Covered in Polyfiber. $9700
Struts are new Airframes Alaska sealed lifetime struts for PA-20/22. Powder coated black. $2750
Everything is located in northern Minnesota.
Additional details:
PA-22 13-rib wings from 1956 PA-22-150, extended per Svenn's SA02790CH STC, which uses Dakota Cub ribs and spar extrusion to extend and square-off the classic rounded-tip. Wing tips not included. I also added rectangular inspection frames at the trailing wing root area to stiffen and avoid drumming. Seaplane drain inserts added. Logbook entry by my IA can be provided.
Covering is Polyfiber process, top coat is Poly-Tone 140 Orange-Yellow. I have 3 extra gallons available at discount so you can shoot your fuselage to match. Original idea was to shoot black leading edges, but this is a yellow canvas for your design.
Fuel tanks included. Ailerons and flaps included but not painted. Pick up in northeast Minnesota near Duluth.
$9700 OBO.
1 postPage 1 of 1
