Thinking of filling a blank spot in my panel ('56 C172TD with O-300) with a fuel flow/totalizer. I have never used any of the aftermarket gauges. Any thoughts out there on brand, installation, etc...
GumpAir wrote:Thinking of filling a blank spot in my panel ('56 C172TD with O-300) with a fuel flow/totalizer...
mtv wrote: It has developed programming problems, and the company has been "less than helpful" in sorting those out.
Jr.CubBuilder wrote:Maybe I'm just a technopohobe when it comes to my plane, but for all the money it costs to install one of those fuel flow meters I would rather put that money in the gas tank. I like my wrist watch just fine, a tank stabber is nice, and I always plan pessimistically for a crappy fuel burn so I'm pleasently suprised when it's less. I don't see any reason to trust an electronic meter any more than a float, or a tank stabber, or my calibrated eyeball. I think they are a waste of gas money.
GumpAir wrote:Thinking of filling a blank spot in my panel ('56 C172TD with O-300) with a fuel flow/totalizer. I have never used any of the aftermarket gauges. Any thoughts out there on brand, installation, etc...
GumpAir wrote:True, but.....
Fuel flow is more of the same. I'm always within a gallon or so using a stopwatch and book fuel burn figures, but still, I want to know exactly what's going on. Things like your friend's fuel leak in spite of the electronics can and do happen, but in the Cessnas, get below 1/2 tank and the gauge becomes useless, and electronics or no electronics that's a "get ya" kinda deal. Also, in leaning an old 80 octane engine using 100LL gasoline, leaning by roughness or a single probe EGT just doesn't cut it. Save a couple of gallons by proper leaning each long flight, it won't take long to pay for a $700 fuel flow meter. Not to mention clean plugs and valve guides.
Bonanza Man wrote:GumpAir wrote:True, but.....
Quick question on the fuel flows. I know you can add fuel to the gauge by a button press or two. But, can you remove fuel the same way? For example I tanker fuel back to my hangar and remove it and store it in a 100 gallon tank. I normally fly around with 40 gallons on board when I'm in the local area. So how easy is it to program the computer up or down?
daveinfl wrote:I've got EI UGB16 graphic anlyzers in two airplanes... I do alot of cross country at night, single engine. About 5 years ago noticed an anomally on a trip (again at night) that caused me to do a compression check and subsequently find a broken ring I probably would have continued to fly with.... for a while anyway.
Also use the EI fuel totalizer.... I've got a Cardinal with world's worst gauges and a 4 hour max limit that I stretch to 3.5. On the other hand, a Bonanza with wing tanks and a 7 hours in fuel will bust a gut before you fly it dry (4 hours in ANY bird is enough for me)... thus a stop watch and some hand calcs are fine.
Bottom line; depends on what your doing with the bird. IFR or single engine at night, I like all the info I can get. On the otherhand, I can see the fuel vial's on the J-3 and I don't figure on flying her at night or in IFR --- at least, I'm not admitting it!
Dave C
Jr.CubBuilder wrote: How do you lean with those anyway? That's a use for them I hadn't really pondered. Why would you prefer a fuel flow over a multipoint EGT?
1SeventyZ wrote:That's interesting, Mike. I have heard the complete opposite, that EI has great customer service.
1SeventyZ wrote: One neat thing about the fuel flow instruments is that (at least with the JPI) you can input your GPS serial data, and it will dynamically compute your range from the ground speed.
Jr.CubBuilder wrote:Your video isn't working.
