mtv wrote:lowflybye,
Uh, precisely where on a carbureted engine would you have proposed to install fuel injector nozzles????
I don't propose to to install them anywhere. We just got a wild hair and wondered if it was even possible to do and if so what would be the benefit if any of retrofitting it to an O-360. Obviously there is no benefit and it cannot be done. Better to retrofit the IO-360 on the Maule at overhaul.
mtv wrote:Even FUEL INJECTED Lycomings don't need GAMI's either by the way, since they use a different fuel distribution system than Continental does, and their fuel flows are already well matched.
Agreed...as stated previously: I have been told by many people that the Lycoming engines run pretty balanced from the factory and the GAMIjectors do not help much.
