AOPA wrote:Question: What is the best way to remove frost or ice from my airplane?
Answer: If you are not pressed for time, have your flight school or FBO put the airplane in a heated hangar for an hour or so to allow accumulated ice to melt off.
Golly how come I never thought of that?! 'Course, being pressed for time, I'd still probably opt for beating on frozen covers and engine blankets, scraping the entire airframe with a push broom, hauling hot water in pails, jugs, or even air-pressurized fire extinguishers, lighting off the Northern Companion, or maybe firing up a Honda generator to run a propane-fired hot-air blower, and oh yeah- trying to somehow get some heat inside the cockpit so that the windscreen doesn't instantly frost up when I finally climb in, huffing and puffing.
