Best you can do is the cessna boots. I have heard of some fashioning a stainless leading edge guard and putting it under the rubber also. I can't vouch for it but it seems like it should help too.
M6RV6 wrote:Guess I'll be an ass and say if it never happened to me it must not be able to happen or someone is telling a tale!!
Worked off gravel and rocks and sand and beach's with 7 Cessna airplanes and did about 3000 hrs a year for awhile, you can tear the shit out of the tail with out hitting anything with the prop. The ding in the Wilga tail is pretty minor and also pretty dam common for anything workin off the pavement.
akgreg wrote:All he asked for in the OP was info about generic rubber. Not your opinions about all this other BS.
CamTom12 wrote:8GCBC,
You didn't start off asking questions. You started off with an unfounded accusation that is NOT in the spirit of this forum.
OP,
I had some minor paint chips in the leading edge of the horizontal stab from some gravel strips. The guys at Chena Marina Air put on some thick 3M tape (I think PVC?) while they were doing some other maintenance for me. Kept any future chips from happening, but I don't think it would have stopped something like that ding you have from happening.
Post up what you end up doing, I'm curious what you come up with!
Scolopax wrote:Bungled up a horizontal stabilizer once when a hidden rock in a soft/rough field was thrown up from my tire. It seems that I found the only rock on the strip big enough to damage my tail this bad. The protection offered by rubber on the leading edge is certainly limited to gravel and small rocks. It was clearly inadequate for this situation.
8GCBC wrote:Scolopax wrote:Bungled up a horizontal stabilizer once when a hidden rock in a soft/rough field was thrown up from my tire. It seems that I found the only rock on the strip big enough to damage my tail this bad. The protection offered by rubber on the leading edge is certainly limited to gravel and small rocks. It was clearly inadequate for this situation.
Beaver Marsh (S2S) ? I walked it last year and there were way too many rocks (throw on the runway by vandalism). I stop going there due to personal quality control issues. There seems to be a lot of section (8) housing there now.
Scolopax wrote:8GCBC wrote:Scolopax wrote:Bungled up a horizontal stabilizer once when a hidden rock in a soft/rough field was thrown up from my tire. It seems that I found the only rock on the strip big enough to damage my tail this bad. The protection offered by rubber on the leading edge is certainly limited to gravel and small rocks. It was clearly inadequate for this situation.
It was in Idaho.
8GCBC wrote: Ferry permit or local mechanic? I think I known what the answer is![]()
Scolopax wrote:8GCBC wrote: Ferry permit or local mechanic? I think I known what the answer is![]()
I'll tell you the whole story when we meet up sometime.
(more?? Users browsing this forum: No registered users and 0 guests
