Hello. I just purchased a 2016 Glasair Sportsman. The engine and airframe have 130 hrs. Engine is running great and just finish flying it from WY to CA.
Engine is a Mattituk tmxo-360 with Vetterman exhaust and has the EFII fuel injection and electronic ignitions.
The number 1 and 3 CHT’s are running warm compared to the 2 and 4. I’m having to run the engine rich to keep the temps at 400 deg in cruise. And I really need to keep and eye on the temps on any type of climb.
The 1 and 3 cylinders are running about 30-35 degrees hotter than the 2 and 4. But even in a climb the 2 and 4 temps stay pretty steady where the 1 and 3 climb.
The engine is baffled nice and tight and I can’t see where any intake air is escaping outside of the box except 1 area.
Right behind the #4 cylinder there is a 3” duct that has 3” scat tube coming off and going down to a plenum that’s is flowing air through the oil cooler.
My oil temp is right around 206 deg.
Do you think if I add a NACA duct to my cowl and run the 3” tube to the NACA and close off the 3” duct behind the #4 cylinder that this will sort out my temps?
