From time to time people wonder about the strength of the various camera mounting systems is. Here's a gopro *suction cup* mount that stays on despite a crash in the woods. Impressive.
idair wrote:Is the strut far enough away on the typical C-172 prop that you can avoid the annoying prop affect?
soyAnarchisto wrote:I mounted (and would mount again if I owned one) a gopro to the most outboard inspection plate of the 172 - which is further out than the strut - and keeps the prop and the jelly roll to a minimum. I've done it with the suction mount - but it's a matter of time before you lose the camera. I would fabricate a small and more secure replacement inspection cover with the gopro arm more securely mounted - and set it up so the camera is just in front of the leading edge of the wing.
rw2 wrote:idair wrote:If you want the plane in the shot, this will greatly reduce prop artifacts: http://www.sportys.com/PilotShop/product/17969
rw2 wrote:rw2 wrote:idair wrote:If you want the plane in the shot, this will greatly reduce prop artifacts: http://www.sportys.com/PilotShop/product/17969
Just found this alternative this morning. Tons cheaper.
http://www.eyeofmineactioncameras.com/G ... esnp-3.htm
Sierra Hotel wrote:Just ordered one - thanks for the legwork!
Addicted2climbing wrote:is the only way for me to attach a pic is with a URL? I'd like to show my mount but my photos are all local.
Marc
rw2 wrote:Sierra Hotel wrote:Just ordered one - thanks for the legwork!
Excellent. I'd love to see a before/after video when you get it. I'm thinking of getting one in a few weeks when I'm in Chicago.
rw2 wrote:idair wrote:Is the strut far enough away on the typical C-172 prop that you can avoid the annoying prop affect?
If you don't want the plane in the shot, then just point the camera in such a way that the prop isn't in the shot. There is no rule saying that the camera must be pointing directly forward.
Sierra Hotel wrote:rw2. Here's a short clip I did an a recent flight with the polarizer filter. Overall, it makes the prop issue tolerable. Now I've got to try and tackle the vibration thingy . . . .
