Next stop debtors prison
RobBurson wrote:275HP ???
Glidergeek wrote::D With the McCauley 86" prop and the extra hp I've picked up over 10 mph TAS at the same power setting that I used before. I'm seeing 20 more indicated mph used to see 125 IAS now seeing 145 IAS, also increased my fuel burn from 11 gph @ 50 deg ROP to 13 gph @ 100 deg ROP.![]()
Next stop deters prison
mtv wrote:Glidergeek wrote::D With the McCauley 86" prop and the extra hp I've picked up over 10 mph TAS at the same power setting that I used before. I'm seeing 20 more indicated mph used to see 125 IAS now seeing 145 IAS, also increased my fuel burn from 11 gph @ 50 deg ROP to 13 gph @ 100 deg ROP.![]()
Actually, if you're burning more fuel per hour, you cannot be using the same power setting. Power setting is defined as a percentage of horsepower, and I suspect what you're talking about is actually rpm/manifold pressure settings.
The same rpm/mp settings on different engines can provide VASTLY different power settings, and that's what you're describing.
A certain power setting will result in a specific fuel burn. More HP, more fuel. Less HP, less fuel. and vice versa.
Sounds like you've got a nice setup in any case, and the advantage is that you can either cruise faster at higher fuel burn, or cruise the same speed as the old engine at the same fuel burn.
shortfielder wrote:Mine had the cyls replaced around 200 hrs. Probably around 5 yrs. ago
shortfielder wrote:[quoteHp sure puts a smile on ones face. Enjoy.quote]
I call it the grin factor, priceless![]()
In my mind, it was the single best mod I did.
I'm hopin Pat gets one for his.
Gary
qmdv wrote:You can count on Corona going into neptuns domain every now and then.
