GPS coordinates
Fri Oct 03, 2014 12:26 pm
Is there a way to convert Fireflight co-ords to Garmin co-ords? The ones I've seen are different formats, and I'm not sure if they can be converted or not.
David
5186
do you mean Foreflight. I don't use the electric gadgets but tried to google Fireflight and it just wants to show Foreflight.
Is this what you are looking for?
http://indyairrace2014.blogspot.com/p/t ... nates.html Multiply the decimal X 60?
tcj offline
1278
tcj
Ya I mean Foreflight. auto correct got me and I didn't proof read it...
5186
Seems like the decimal multiplied by 60 is the trick. Thanks tcj!
5186
There are a couple formats commonly used for GPS coordinates. One is degrees, minutes and seconds: 60 degrees, 30 minutes, 10 seconds, for example.
The other most common format is decimal degrees: 60.67894 degrees.
Do a Google search for converters from one to the other.
I've also seen some other not so common, and maybe not even "real" formats.
And, of course, there are different GPS databases.
10515
I believe the digital format is called "geocode". I rigged my garmin GPS to display current position using this format, I figgered it'd be easier to tell ATC where I was crashing that way.
10535
Well I figured more things out today. My Garmin was set in the degrees minutes and seconds. I figured out now that i can easily switch it over to decimal degrees. As tcj mentioned in his post, it is easy to convert decimal to minutes by multiplying the number afrer the decial by 60.
Thanks for the help all.
David
5186
Users browsing this forum: No registered users and 27 guests
