Hand propping mt propeller
Im sitting here waiting patiently for my maule to preheat and got to thinking about getting in a situation where it needs hand propped. Im curious because they start awful fast. It just a two blade but still...
Thoughts?
gassman offline
47
- Aircraft: Mx7-180
Never understood why we don't put a nice pulley right behind the spinner.
2854
I’ve hand propped Huskys with O-360 Lycomings with MT props a few times. It’s no big deal. Be sure the prop is installed with blades at 10 and 4 o’clock, viewed from the front. And I almost always prop from behind the propeller.
10514
I’ve seen a pponk’d 180 with a 3 blade MT get hand propped. I was uncomfortable just watching! They did a good job getting it started though.
3263
- Aircraft: 1957 C-180A
I hand prop my 55 C170B with a 3-blade MT prop on a Lyc O-360. Every other blade will line up with compression where you want it. I rotate to that position, turn mags hot and pull from the front with a person at the control who knows how to run the engine when it starts or if something goes wrong. I always prime , then pull thru at least 4 compression strokes before every start anyway..always treat prop moving in normal direction as if it will fire during the compression stroke. Chock tires, keep throttle back, have someone at the controls adn turn the engine off with mags to insure they really are not hot when you think they are off. Do be careful of large bulky rings and wrapping your hand too far over the trailing edge of the blades as when you pull through, the ring will try to chip the surface of the trailing edge...first knuckle only for safety also.
john54724 offline
112
Thanks for the replies. Sounds like it isnt much different than normal.
gassman offline
47
- Aircraft: Mx7-180
Shouldn’t be any different than a Cub with a wood prop.
IOW, like a light switch.
Cannon offline
282
- Aircraft: C-185
Piper J3C-65
Pitts S1S
