There's a private public-use airport nearby. A friend of mine bought a hangar custom-built for him by the guy who owns the airport (a local farmer). The doors are the roll-aside type, but 100% of their weight is suspended from above. He used some type of irrigation pipe (maybe 3" diameter) welded at the top to a flat piece of steel (maybe 1/4" thich by 2" tall) that runs end-to-end and is bolted to the door frame itself. He used an externally attached "trolley" system to support the door itself. IIRC, there were only two sets of trolleys supporting each of the doors, but for larger doors, one could easily add a third trolley. The rollerblade wheels run along the irrigation pipe, with one pair of wheels outside the door, and the other pair inside the door, held together with bolts through the door frame. (He said they used LockTite to prevent the bolts from loosening, and the upper trolleys are all non-adjustible mount points – nothing to potentially loosen and create misalignment.) Those rollerblade wheels are set at roughly 30º from vertical, so they roll easily atop the irrigation pipe, and support the door's weight properly with minimal torsion (flex) on the bearings.
Having the trolleys sandwiching the door and the upper rail (irrigation pipe) keeps the door on track, even in some pretty high winds. The bottom of the door has another set of trolleys, with rollerblade wheels aligned parallel to the ground, but rolling in a narrow u-channel set with the top at floor level. Those attachment points had some adjustability to ensure minimal "pinch" friction. That keeps the door from swinging in or out. That lower u-channel was slotted for drainage. The doors themselves feel quite substantial, yet they can be pushed open with literally one finger! Everyone who came to the EAA chapter fly-in he hosted had to try them for themselves. Easiest opening hangar doors I've ever seen! And the cost was amazingly inexpensive (if anything in aviation can be considered "inexpensive").
If I ever build a hangar (or a barn, for that matter), I will probably use this type of door system.
