Jr.CubBuilder wrote:Did MT come up with an STC for our planes, or did you go with a one time approval? I think I asked you about the prop before, but I can't remember if you had it in the air or not at that point.
Pundy wrote:The 170 that I'm buying has a 180hp conversion with a Hartzell constant speed. The prop looks kind of short and fat. The part # is F7666A. Does anyone know anything about this prop? Good, bad, or otherwise?
Glidergeek wrote:Pundy wrote:The 170 that I'm buying has a 180hp conversion with a Hartzell constant speed. The prop looks kind of short and fat. The part # is F7666A. Does anyone know anything about this prop? Good, bad, or otherwise?
Who's STC is it Pundy? Check and see if this prop assembly is even approved for that application.
