I have '96 MX7-180C. I just put VG's on and here are the stall numbers. Aircraft weight in the test configuration approximately 1980 pounds. 2500' msl, close to standard temp and altimeter.
configuration pre VG (mph) post VG(mph)
Flaps up, pwr off 54 48
Flaps up, pwr on 48 48
Flaps 2nd notch, pwr off 45 38
Flaps 2nd notch, pwr on 42 38
Flaps full, pwr off 38 30
Flaps full pwr on 0 indicated 0 indicated
All speeds are mph. Airspeed arc speeds are 47 and 62, that's at 2500 lbs though. Speeds below 40 are a close approximation since 40 is the bottom tick mark on the indicator.
Full flap stalls now have a more pronounced negative pitch moment on stall. AOA is higher going into the stall so you would expect that but it'll make your eyes bug out the first time you do it.
So it depends on what you are doing with the plane. In and out of short strips? Go with the VGs. Cross country into nice long fields? Go with the mogas. Though with the mogas you may end up at more than your $800 since I think fuel pump replacement is required and unless you're a mechanic the cost of labor will be higher. With VG's you just need an IA to sign off the 337 once you do the installation. VG's were right at $800. $695 + shipping + mechanic.
